Sorry as I could not find a location for putting this. I used images from a vaction trip and imported it into Nero CD Designer but cannot override some of the background colors. Ideas ?
there are free templates located on the neato web site for many apps ..
or cd/dvd label pro works fine .. -
neato is by far the best for making dvd labels. to download the actual labels form the dvds you should check this out http://www.cdcovers.cc/
http://www.neato.com/Originally Posted by tokyootaku
the "Metallic Foil CD/DVD Labels for InkJet Printers" seem o work on dvd ok -- tried also the glossy lables..
but it is true as others have said that in fact, you are not really supposed to use labels on dvd's .. ive seen paper labels come right off them before..
What Is The Easiest Video Editing Software For Beginners That's Free?
By Joshua P in forum Newbie / General discussionsReplies: 19Last Post: 16th Apr 2013, 09:24 -
Cheapest/easiest software to create an electronic personnel action form?
By wetcamelfood in forum ComputerReplies: 2Last Post: 15th Jan 2012, 08:58 -
Easiest software for compilation, cutting/joining?
By jiopi in forum EditingReplies: 0Last Post: 14th Oct 2010, 13:31 -
Easiest software to convert Dual Audio/Subtitle MKV to WMV or AVI
By greasyspoon in forum Video ConversionReplies: 1Last Post: 9th Sep 2009, 13:43 -
what is the easiest software to cut an audio file?
By marlo in forum Newbie / General discussionsReplies: 2Last Post: 2nd May 2008, 14:45
